Hello,
i tried to use the Dante-Card for virtual sound check and recording but got some realy strange problems. The firmware of the card is V3.6.4 and i thing that ist the most actual version. But i have the following problems that i could not solve:
If i send signals of the DAW to the channels of the Card only channel 1-8 and 25-32 will receive signals. The other channels are dead.
No output is send from the GLD to the Dante virtual soundcard. I set up all output to direct out of the input channels. No audio.
I have a 01V96 with a Dante-Card installed. If i connect the outputs of the DAW to that channels all is running fine. So i thing the basic setup would be OK.
Can it be a hardware problem of the dante card?
Thank you for any help…
Carsten Spräner
https://www.canto-forte.de
You didn’t mention the Dante Controller application and settings? I assume that you are using it and all channels are being routed correctly? Also, the Dante Controller now indicates whether audio is being passed on a Dante Channel - very useful for trouble shooting.
Bob
GLD80, AR2412, 2xAR84, Dante, GLD Remote
I used DANTE-Contoller Version 3.4.2 (not realy shure!) to set up the routing. The DVS ist set up to 64 channels. All channels from the DVS are routed to the A&H channels. This way only the first 8 channels arrived in the GLD. I set up nothing special for the other channels.
Than i tried to set the output of the DAW to Channel 25-32. This channels also arrived in the GLD.
I didn’t got any channel from the GLD into the DAW nor in the 01V. Nothing leaves the GLD. This was does not work at all.
When i’m back home, i will check the versions of all components. But im quite shure i checked it to be all up to date.
Yes - troubleshoot with the Dante Controller capabilities to determine possible set up issues in the system.
Good luck
Bob
I checked the versions. My DANTE-Controller is now V 3.6.4 and i have a Signal on all DAW-Channels 1 to 30. But there are only Signals in the GLD on 1-8 and 25-30! Very strange!!
The other direction GLD->DAW doesn’t have any signal on any channel.
I will send the DANTE-Card back to the dealer. I realy think it is a hardware problem.
If i get a new card i will post my experiences.
GLD 112, AR2412, AR84, DANTE
