We have been working a dLive for over a year now, and have recently invested in a Dante card (mainly for future networking expansion.) The card has been installed and we are wanting to experiment with tracking some songs/live performances. I have installed Dante Controller and DVS on my MacBook Pro (Logic Pro is the DAW software) and have made 44 “subscriptions” between the dLive and the laptop in Dante Controller.
I cannot get any audio into Dante Controller or Logic. The speaker icon shows no color when audio is passing through channels with subscriptions. It seems all is well between the laptop and Dante card, as network status shows green, etc. Am I missing something in the dLive that needs to be pressed or activated? Any help is appreciated greatly!
A few suggestions:
Dlive output patch “direct out”-“post preamp”, and its matrix is correctly configured.
Logic pro input channel list, accepting from DANTE network, arm the channels.
Is there a direct network cable in between your laptop and dante card?
Where are you located Barry?
patch outputs in dLive to the Dante card using direct outs or tie lines (there is more ways, but for multitrack recording those are the 2 to choose from)
start DVS with the minimum number of necessary channels
patch Dante channels from Dante card to DVS (computer) from within Dante Controller
patch inputs in your DAW
you have told us about 2 of these 4 points so far. Does Dante Controller show all network connections? Is the device info correct?
Dante is not just plug and play until it is setup correctly…
regards
The piece missing was the patching of direct outs or tielines within the firmware. I have the rest of it put together and Dante Controller shows 44 subscriptions. Thanks much for the assistance.
Unless you have specific reasons for using direct outs or tie lines, I would try and stick with VSC (virtual sound check) record send. You can assign a sequential block of channels and easily manage the send/playback. This also means if you change an input patch the recording will follow.
If you have non-input channels, add them into the IO matrix after the VSC channels and record them (eg, L/R).
Have not tried the record send option yet. Thanks for the heads up.
But this means, I have to enable “record send” before I want to record? So one more button to think of?
You can leave “record send” active all the time, just reset it when you repatch inputs in that block to pick up the change (I don’t think this has been addressed yet).
My system is out on a different show each time, so I look at this as 60 less buttons to press. Select the block of channels you want to record and enable “record send” - what you don’t have to do is map direct outs or tie lines for each individual input channel, and with tie lines you have to remember to reassign them if you change the input. I do map L/R/C/Sub and other final mixes to also capture them, which has to be done separately.
Most of my recording is actually done via a Waves interface @ 96k and it isn’t unusual to record 60-80 channels at once. Works beautifully.
I used the VSC Record send button and it works just fine. Doing the soft patching in Dante Controller allowed the inputs to come to the DAW in the order I wanted, so Logic Pro input patching was one-for-one.
So I take it that outputs can be mapped along with the VSC “batch” simultaneously? I would like to learn more, please.
Jay,
I have re-thought and tested your remarks on record-send mode.
As my recorded channels are not the same as the ones used for virtual soundcheck, this options seems not to work for me.
Unless I still have not understood the “concept”. What is likely as I still don’t get your sentence “If you have non-input channels, add them into the IO matrix after the VSC channels and record them (eg, L/R)”.
Where in what I/O Matrix are these channels to be added?
The channel pick up point for the Record Send option is just after the analogue preamp and converter, before any Digital Trim or processing. It’s a good choice for general multitrack recording use or virtual soundcheck (where the channel processing would only be applied at playback).
If you wish to record the signal after the DEEP Preamp model or channel processing, you have to look back at the Direct Out option suggested earlier in this thread.
