I’ll try to keep this brief
…but I could use a spot of help with getting Dante up and running before the weekend.
My new Dante rig seems to be connecting fine with one unfortunate exception: No signal is shown in the Dante Controller (device view, DVS selected, receive tab), even though the desired channels are displaying green check marks and the correct mapping is shown. Likewise no signal is seen on device view, m-Dante selected, transmit tab.
I’ve double-checked the iDR I/O patch for Port B: Dante, and Dante ports 31 and 32 are assigned to my test sockets (31 & 32, stereo) and set to “input - direct out.” The Editor channel strip shows good signal; it’s “on” and unmuted.
Where have I gone wrong?
iDR-32 1.91
m-Dante 3.6.4
Windows 7 Pro SP1
Dante Controller 3.4.2.2
DVS 3.2.1
Reaper 4.54 x32
iLive Editor 1.91 (on a separate computer)
The Controller/DVS computer is connected directly to the primary port of the m-Dante card; it is a GB connection. Unique static IPs have been assigned to the m-Dante and the computer. The m-Dante is set to “switched” mode.
The Editor computer is directly connected to the iDR internal switch.
