Dante setup in Dlive
I have 2 dlive setups in the theater I run. This is probably a simple question, but I can’t find an answer in any of the threads. The CDM mixrack has a dante card in it. Both my primary and secondary are run there. Do I still need to have my surface (s5000) plugged into the dante network? The installation company that did the original install when the building was built 3 years ago connected the surface via the network port to the dante network. When I plug in my router to control the surface via ipad, I lose the whole dante network and have to re-address everything (amps, wireless, surface, etc) for the dante network. Please advise.
Which Dante card?
Ha? That makes no sense at all.
More information please…
That has nothing to do with the desk, it’s your WiFi configuration that not matches to the needs.
You need to rethink your setup!
a cat from the dante network is plugged into the network port on the back of the s5000. plugging in a router which i have configured to use an ip range that jives with the surface will completely throw the whole dante network into a tizzy. system doesn’t need to be redesigned. there is a dante card installed in the mixrack. will the surface still be able to access the dante network if it is only connected to the mixrack via gigace? i have a feeling the install company made a mistake by connecting the dante network into the network port on the back of the surface. trying to verfy if that is correct or completely off.
basically can i unplug the dante line from the surface to make the system happy or will it no longer have access to the dante network? when the router is plugged in dante controller says a non dante device is on the network.
You left out some information. You said both surfaces are run “there”. Where is there? How is it connected? If there is no Dante card in the surface, then you should not plug the surface into the Dante card in the mixrack. There would be no reason to do this and would cause conflicts especially if bridge mode is enabled in Dante controller.
Long story short, he surface’s gigace ports should be plugged into the gigace ports on the mixrack. The network ports from the surfaces should be plugged into the network switch and depending on the configuration of the Dante card, the primary port should be plugged into the network switch.
Based on some of the issues you described, there may be some additional IP configuration that needs to be done to avoid IP conflicts.
You don’t need at all to put a Dante cable in the Surface.
You just need a Dante cable in the Dante port of the Dante i/o expansion card. Thats all you need to have Dante audio.
If you want to access Dante controller from the surface side, you can integrate the “Dante network” with the “dLive control network”, this can be done in two ways :
  • If you have a modern a&h Dante expansion card with the “internal network bridge” switch, if you turn that on, it will mix the Dante network with the dLive control network, and you will be able to connect a computer on the surface for example (or in any network port of the mixrack or surface) and it will have acces to dante control network (the Audio part of dante will be filtered out, you cannot access Dante audio from there, but the dante controller will work)
    You will need to be sure about how ip are assigned in a good manner.
  • If you don’t have a card with that option, a common way to do this manually is to put another cable from the dante network to the “control network” of the mixrack (or this can also be done to the network port in the surface), the thing is that the gigaAce port and all the “network” ports in mixrack and surface are connected internally in a lan. This way once you put dante network in some port of that network, it will be available in every port of the network. I think all this ports will also filter audio, (or you should, to not mess up with the gigaACE capabilities), but you will be able to access Dante controller.
    Also, you need to watch out for ips …
