Hey guys, can someone help explain to me exactly what I need?
I have an SQ6 at FOH with x2 DX168’s. I also currently have an SQ6 that I am using as a broadcast console and they two consoles are connected via an I/O port at FOH and send tie lines to broadcast. I would like to get rid of the broadcast for a different purpose in our building and so I am looking at Dante to connect the 2 desks.
Can someone confirm that to do this I would need: Dante card at FOH, Cat cable from FOH Dante Card to network switch upstairs (where broadcast console normally is), connect Mac running Pro Tools to the switch and purchase Dante Virtual Sound Card and Controller for use on the Mac and I will be good to go? Or am I missing something? Do the DX’s need connected in or will they be okay since they are connected to FOH SQ via SLink port? Thanks.
You can’t directly connect the DX boxes to the Dante network. However once you have a Dante card in the FOH console, you’ll be able to route any of the I/O (local or connected stage boxes) over the Dante network using the routing tab. There are several routing options/methods and you might select one method over another depending on the exact goals of the system. In this case where you simply want to send “raw” source to a broadcast DAW, tie lines would be the most appropriate IMHO.
As far as the required equipment, you don’t need a switch if you only need to connect the console’s Dante card to the computer. You can use the Cat cable and have a direct connection between the two devices. A switch is helpful if you have several devices you need to connect at a single location, but it also adds complexity and potential failure points to the system. I personally would not use a switch unless I needed the extra capacity that a switch offers.
The rest of your assumptions about the required equipment are correct however. You will need a Dante card in the SQ console as well as DVS software licensed and installed on the computer.
Luke & Brian I hope you don’t mind my adding another question to your post - I’d like to know if the following would work: Two SQ6’s (FOH and live stream), the FOH SQ6 feeds an ME-U hub via its built-in SLink port and reads XLR inputs from a DX168 via an I/O port SLink card. Problem is how to send the FOH SQ6 48 channels to the Stream SQ6 since there are no more SLink ports on the FOH SQ6 and A&H doesn’t make a dual-port card. Would it work if I daisy chain from the DX168 to the Stream SQ6’s SLink port? I think I could pull it all off with a dual-Dante-port I/O card and a DT168, but want to know if the above cheaper solution would work. Thanks in advance for your help!
Option #1 - you could use a GX4816 as your main stage box. This stage box has a ME port built into it which means you can connect the GX4816 to the console via a SLink port and connect the ME devices right to the GX4816 - effectively “saving” an SLink port on the console. You could then use the second SLink port to connect to the second console. While this isn’t a cheap option, it is certainly cheaper than getting two Dante cards and a DT168 to accomplish the same thing.
Option #2 - move either the stage box or ME connection to the second console (Livestream). You’ll need to get a second SLink card for that console as well, but then you could connect the two consoles together using the free SLink port. The FOH console will need two SLink ports with one connected to the livestream console, and the other connected to the stage box (or ME). The Livestream console will have one SLink port connected to the FOH console, and the other port connected to the ME box (or stage box). This is certainly a cheaper solution, but requires the Livestream desk have two connections (one to FOH and the other to the stage for either stage box or ME use). Depending on the facility, this might be possible or impossible to add.
Option #3 - use Dante to connect the two consoles together instead of SLink ports. This is the solution if you think you’ll need Dante for other purposes. The rest of the solution can look exactly like Option #2 however. There is no requirement that you use a DT168 box when you have an SLink port available for the DX168 box. If the wiring requirements of Opt2 and the Livestream console don’t work, then you could go to a DT168 box and use the SLink port on the FOH console for ME use.
Hopefully you can follow my explanations well enough.
I always forget about the AR2412 stage box. This is another stage box that allows the ME system to connect directly to the stage box (like the GX4816). This is an older stage box that operates at 48k. The newer DX/GX stage boxes operate at 96k. The main difference is that you cannot connect the two types of stage boxes using the same SLink port. In other words, you can’t daisy chain the DX168 to the AR2412 (or vice versa) for expanded I/O. You can use both style of boxes on the same system, but each “speed” of box needs their own dedicated port of the appropriate type on the console to connect to.
The AR2412 is quite a bit less expensive than the GX4816 (which makes sense because it only has about half the I/O of the 4816), so that may be a more economical solution.
It has nothing to do with the original Dante request, but since you mentioned the AR2412, allow me to mention the AB168 as well.
It has the same quality as an AR2412, but the size of a DX168 or DT168.
And 1 or 2 AB168 or the combination of an AR2412 and AB168 also allow to connect ME.
If I have an SQ7 at FOH with all local inputs and have another SQ6 for broadcast, am I able to route those inputs from FOH to the SQ6 broadcast console over the SLink network? Dante? Is one option better than the other?
Hi Ian,
Yes - you can do this, using either IP Direct Outs or Tie Lines.
You will need to ensure the second console is clocking to the first - so set the clock source to SLink (or IO port if connected using an option card).
Unless you already operate a Dante network and don’t plan to install one anyway, the SLInk solution is certainly the best option for you, because you only need one Cat5e cable for it and the setup is much easier.
Even if you decide to add a digital stage box in the future, you’ll only need an additional SLink card for it, which costs only a fraction of the price of two Dante cards.
Dante is a great solution for a lot of problems. I use it all the time.
However I personally would always default to using the proprietary A&H protocols whenever possible. It’s not that Dante is unreliable, but the A&H protocols have less user controlled settings/requirements and therefore are more stable by definition. Basically the A&H protocols are completely plug and play while Dante sometimes networks can take some tweaking to make work correctly. (Of course both solutions still require that the audio is routed correctly as well, but that isn’t part of the physical connection method).
Therefore if your two SQ consoles have the built in S-Link port available, I would absolutely recommend connecting the two consoles together using those connections. Even if both consoles had Dante cards installed, I personally would still rather connect the two consoles together using the SLink port. Of course this assumes a “perfect scenario” where you have the SLink ports available and ethernet cables in place to support this option. Depending on the actual situation you find yourself in, Dante might be the most logical/cost effective choice to use. If that is the situation you find yourself in, then use Dante for this connection. It will work just fine once it is set up correctly.
Long story short, personally my first choice would be to use the A&H protocols, but Dante is a great second choice and I would choose it over the A&H option if the cost and ease of implementing the Dante option trumped the A&H protocols.
