Will it delete my Library saves of if initialize my SQ6. if yes, is there is a way to save my library
Hi AndyC,
All library files are stored in the show file, which can be saved to a USB drive. However, if you are resetting the mix settings, your library files will not be erased.
You will only lose these settings if you hard reset the console to factory settings, or if you load a new show file onto the console.
Thanks! Alex
