db2 xone
Hi all,
could use some help, As per the below, when using the upfaders only, should i use “mix” and only assign effects x or y when wanting to use the filters etc.? Why then when assigning a channel to x r y is it softer or quieter than mix??
please could you assist
XFADE / FX SWITCH
Selects where the channel output will be routed:
MIX (Centre) - Routes the signal directly to the mix
X - Routes the signal to the input of FX-X or to X xfader
Y - Routes the signal to the input of FX-Y or to Y xfader
kind regards
wadem
@wadem ,
I do not believe there are a huge number of XONE users on the digital community (though hopefully I’m proven wrong!) so if you don’t hear back from anyone here, please contact us using https://support.allen-heath.com and you’ll be able to chat with one of the XONE team about this.
Cheers,
