DCA channel meters
It would be very helpful if the channel meters on DCA channels would show the levels of the assigned channels.
I know, that no signal is routed through a DCA as it is on a VCA in the analog world. But in the digital world
this should not be to too difficult to implement, because it’s already possible to hear the PAFL signal for a DCA channel
(at least it’s possible to activate it in the editor, I have not tried that on the console, but will do next time)
Best regards,
Edi
Not sure it would help much even if it were possible because, like the PFL, it would presumably be the sum of the PRE fade levels of the component channels. So what would it tell you? That there is SOME signal?
This would be a nice addition. It wouldn’t necessarily need to be the sum of the signals in the group, but could be the hottest signal in the group instead.
Why should it have to be the summed pre fade level signal? The hint with the already existing PFL Option was just to show, that it is possible to hear a signal where physically no signal is.
I would prefer the channel meters to behave live the meters on a subgroup channel.
Just show the sum of the post fader signals of the channels controlled by the DCA.
Early iLive firmware had meters working on the DCA masters - then some people who couldn’t get their head around that complained so A&H got rid of it to avoid confusion. Personally I really liked the feature and would prefer it back! Or a user option for it?
This would be a nice addition. It wouldn't necessarily need to be the sum of the signals in the group, but could be the hottest signal in the group instead.
If you are going to put a meter it, which doesn’t make much sense as it has no audio path, ‘hottest channel’ makes the most sense. If it sums, it has the potential to ‘clip’ a meter for a bus that doesn’t exist, which is just confusing.
+1 for DCA metering - the M32 and X32 boards support this in what I believe is a hottest channel config. If it’s confusing, why not just make it a toggle, disable it by default, and make a pop-up that confirms what the option does before enabling?
