This idea on an old post would provide the capability if implemented:
- Simplefied option: global Aux setting following LR channel mutes “On” or “Off” (DCA is only affecting LR channel volumes when Aux is set to Pre fader right?). With the option “On” when DCA mutes one or multiple LR channels, Aux output of that channels is also mute. Whith the option “Off” when a DCA mutes one or multiple channels, Aux output of that channels won’t mute.
- Pro option: set this option per Aux. Add an extra option in the Aux Send settings (go to routing, select the Aux, tap the gear icon.). Besides the option to select channel source, assign and pre or post fade, you can add the option to set the behavior of LR channel mutes for that Aux.
“Follow LR Channel Mutes”
“Yes” - “No”When selecting “No”, if a LR channel is muted (by channel mute or DCA mute), audio is still send to the Aux and to the output of that bus. For IEMS this option seems to suit a lot of people. When using Auxes for different things, like a mix of IEMS and wedges (or name any purpose), you can select the mute behaviour for every Aux.
