DCA routing indication on tabs
1 Indicator. When routing DCA group i would like to have a green indicator dot on each tab that have any element represented in the routing. That would give a good overview without the need to go to the separate tabs to see if there is any element selected in that tab. With seven tabs to choose from it takes time to go through all to check. If they all had their green indicator when used it gets way more effective.
2 Clear selection button. Each tab should have a separate Clear Selection button to be able to clear all selected items in one go.
Regards
Arild Grindheim
I agree - Clear Function will be much faster. I think about an combination of RESET and DCA-SEL.
To Clear a DCA use reset and the desired mix button
if you select a DCA group you will see all it’s members in the screen listed
