Dedicated reverb control for mix outputs?
Is it possible to set up a monitoring reverb purely for the MIX outputs and be able to fully control the amount of reverb added to specific channels on each mix output?
You can set up a monitoring reverb purely for sending to mixes.
There is only one output from an FX unit though, so you can balance how much of each channel is sent to the reverb - but that is then locked into the output to whichever mixes it gets sent.
If you need ‘more ch1 than ch2 in Mix1 and vice versa for Mix2’ then you’re SOL, or you need to burn two FX units.
Digital mixers are awesome, and powerful, but they aren’t magic.
Ok. Thanks Bob.
