I am out of town for awhile but had a customer calling that I recently installed a QU24. Asking if the custom layer could default load at boot up. Seems I tried that once awhile back on another console and could not get it to work.
Does anyone know? Will be a few days before I can get back to try it. There should be a way. I talked them on phone how to set the custom layer up. They just didn’t want to have to switch layers from main to upper just to play a CD. Keep it simple for volunteers. One less thing to trap them.
“Custom Layer Only can be set to lock the user out of the
standard Inputs and Masters fader layers. Admin can assign
just the required channel strips and therefore prevent the user
accessing channels that should not be touched.”
Just checked the Manual, setting up a Basic User with only access to the custom layer may do the trick. So some action is needed (login as admin) to get back the full functionality. If that could work for your customer I may quickly try it.
The price is yours, Mark…
Ok. Well I was trying to save them keystrokes. It seems that a preference could be set to default to custom when booting. If not then there should be one if the scene is designed that way. My biggest problem in training folks is getting them adjusted to dealing with layers.
If the Admin user does not have a password, the console boots with the setup used during last shutdown (with channel layer selected, however you left it).
If there is an Admin password, the console boots locked into the login screen. After choosing Standard/Basic user you still need to press login to get the console switch to the custom layer (user needs to be restricted to the custom layer) and load some default scene.
At least I couldn’t find a setting to select the boot layer. Maybe worth a feature request.
Recalling a scene does not memorize/switch current layer, btw.
That’s what I thought. I feel there should be an option to boot to custom if that’s what the user is going to primarily use. It seems logical for us guys to know what to do but to novices it needs to be as simple as it can be.
As has been said, you can set up the Standard User so that only the Custom layer can be used. I did this for our normal users. They can control all of the inputs and mixes we use, as well as use the DCAs for control of groups used for recording, using only the custom layer. But you are then limited to only 32 faders, unless they know how to use the Blue Mix buttons.
By using the Safes screen, you can protect all parameters for one channel, so that when you select the desired Scene on bootup, the one channel’s setting will not be over-ridden.
This does leave you open to an operator leaving that channel in a “problematic” or unknown state for the next person. I prefer to have the standard scene have one or two critical channels unmuted, but use the Scene and/or Global Filter to protect everything but the Mutes.
The security model for the QU is fairly complex and versatile, but it’s a shame that there are only three user levels, with the Basic level being practically useless. Perhaps A&H will change this with a firmware upgrade.
My familiarity with this is admittedly limited, so I hope I have given you good information that can be used alongside what has been given in previous posts.
I just think the easier thing is for an additional tab in setup/control to select what layer defaults on startup. The GLD works that way except it just comes up where you left it on shutdown. But since the QU series is finding its way into more facilities with novice operators I try to keep things as simple as I can.
There is not much in the manual around these areas and I had to experiment to find ways which provided safe and repeatable operation for the basic users yet control and flexibility for the power users.
The Qu powers up into whatever state it was last left. This includes the user type as well as the the selected fader layer in use and fader settings etc. I ask the power users as a matter of courtesy to change the user type back to basic. Upon changing user types, there can be a predefined startup scene for that user which is loaded, which can recall various fader and mix settings.
Using a scene outside the range allocated to users together with applying a simple password to the standard user means that however the desk was left, on power up the basic users cannot help but end up in a known safe state on the custom layer, unaffected by anything that the standard users can do.
Things can still go wrong if there are global safes preventing the total recall of the basic scene.
I tried last week before I left town and the desk always came up on the main layer. Unless I am overlooking something but seems others agree with that otherwise this thread is not useful.
In a church environment it can be helpful to have a “return to base” on startup.
We have a Roland M300, and it is configured to absolutely overwrite everything with Scene000 (backuped up in various places) and select User Layer 2.
This doesn’t restore user preferences (fader assignment etc), so is still vulnerable to advanced operators forgetting to restore those settings.
A “this desk shall be as follows on startup” option is nice.
I agree with [XAP]Bob. I also faced the situation where an easy “restore scene 1 on startup” would be very nice. You csn set this as a softbutton but this already needs some training.
