Ok, so i have looked and looked and I can’t see it.
using either the listen wedge or the IEM, how does one put a delay to bring it in line with what is happing in the room.
Running a PA from 30 metres, obviously there is going to be a delay in the IEM or wedge channel.
but as you select the indicated channel, there is no overview or section to insert a delay.
a must need. if anyone knows how to do this simple thing, please advise
surface > audio > pafl
DC
Davo,
Did you find this okay?
DC
I don’t know about Davo, but I found it! I’m glad this question was asked, I hadn’t thought about time aligning our headphones. Brilliant!
Stephen
Hi DC.I found it perfectly and yes I had done the too hard look and glossed right past it.
time aligning ears or wedges.
coming from venue and midas, it is just a little different to locate.
but this has the good.
I find the update section on scene management and recall filters and global safes to be very advanced.
