I would like to remove some PEQ memories from previous shows from the PEQ library, however it would seem my only choice is to delete the library and not the individual memories…other than overwriting these , is there another way??
“Deleting Library” in Library Manager actually deletes only individual memories or settings, not all library content if you choose memories under “Parametric EQ”.
Just mark those memories and click Delete Library and confirm.
In 1.81 you can click on the individual library items …
I think that this has been the case in few versions earlier.
At least from 1.70 when I got my tools.
iLive T-112 + IDR-48
the reason I asked was that when I first tried this in (1.81), the entire parametric EQ library got erased ( after selecting multiple memories) I had to reload it from the usb …In the editor this is not a problem as there is no multiple selection possible, but, when attempting this on a surface, the file behaves differently than expected…try this:
Select parametric EQ group then “+” to open the group (at this point the parametric EQ group is still selected ) then click on multiple select then add memories , now press delete! since the group name is also selected, the whole thing gets deleted… minor bug in the surface software!
The section headings are also selectable options. In multiple select, just make sure the “PEQ” section heading is not selected before deleting the chosen ones.
If these libs are stored in the current show, you can you safely attempt this and recall the show if you make a mistake (or back up the PEQ libs to USB and restore via that means).
Hope that helps
Regards
Sam A&H
Hi Stealth, thanks for your answer, I did find that out the “long” way…but, as my PEQ list was rather extensive , I could not see the PEQ header still being selected while scrolling down that list, so in that way it behaves differently than selecting folders and contents on a mac or pc…Once you open a folder (ex:PEQ) and select within that folder, the folder itself should not also be selected, only the items inside it should be.
I just got caught off-guard with that one not thinking the “multiple select” tab would also apply to the header…
