Ok,
That’s cool, your holding the data till you decide to commit it to the console…
I’m actually an automation programmer currently mostly crestron…
So, I’m always dealing in real time and so that is my thought unless I see it’s a batch/commit type of a setup…
Not sure how your holding data and such and if your going tout in some form of file control into it…
Right now you get 100 “shows” on the board…and you can dump/upload an entire new config for another 100 each time iirc…so in essence unlimited…but not real bullet proof and easy…
If, once you get the program doing everything including names and everything…
It would be awsome to have the “shows” or config in a nice data structure for easy recal…
I run several outboard pcs on my mixing desk…so having that would be great…and I see that there would be others in a small studio that may like/need this too…
FYI, my private studio is where the qu I going…qu-32 just waiting on arrival…just about 1000 square feet…24x10 stage on one end with 24x6 built in snakes…and stepped seating for use on demos with bands and I also use the room for a movie theater as well as live…running 9 QSC k series for mains…2 ksubs…and k10’s for stage monitors
Currently running a Yamaha 32 channel board…and have several audio interfaces…but needed more channels, and more daw control, total recall etc…
This is just a practice/scratch track/live room exclusively…and the tracks are used to capture the dynamic feel of the sessions to keep it real and live sound, even though most tracks end up getting dubbed over…
Anyhow, I’m looking forward to the board arriving and patching it in, I can see a real need to go beyond the ah internal 100 config…
I currently have about a dozen acts I work/produce and they all have a fairly wide array of songs/setup…
My original plan was a USB key for each act…albeit not great I think it will work…just having to swap them and whatnot is just a pain…inevitably there will be the misplaced USB stick, inadvertently storing one act’s scene on another’s…etc
Now, jump on my pc that is used for sequencing dmx lighting and programming the EC dc-one’s for the room eq, delays, breakout, etc…would be perfect…
Open up your program, browse to the current act (folder) pick the song/performance and load it in…
Now, I’m hoping you’d be able to save current config…but if not its still usable…just have to replicate changes off line and resale the show…
Let me know what your thoughts are, as I see this as a nice feature/add on package…
Even adding into the up/download he full user library would be totally trick…
This board does have a split personality
one being live, no need for a pc, and quick setup via dsnake and powerful for shows
Two being installed/studio (albeit not for production) space using the USB audio nterface, daw control, automation, via protools or in my case I use audition for editing…I don’t like virt instruments an if needed I have other systems for that…I like to keep things separate…
Recording for production I have other spaces…one neve…and another ssl 4056G+ with konecktor…
I do see this becoming for studio use a very handy and whial not essential will streamline the workflow…
