Hi everyone,
I was wondering if anyone had some experience working with a Digital Drum Set TD-30, ( like setting up the channel strips etc)
I have not setup a digital Drum Set and also dont know how it will connect to the mixing Console ( to be discovered).
I runs of a roland drum machine. Not sure if it runs of a master output and or allows to connect each individual part of the drum kit per channel.
if the later is the case than I should be fine.
I just don’t want to wait till I meet that guy on the life set to know what to do about it.
I would appreciate if you could share any experience with a digital Drum set, particular the model TD-30.
thank you
Cheers Norman.
