I know this is a dumb question but I can’t find it in the manual… how do I reduce the brightness of the gooseneck lamps im using?
Hmmm M7 LS9, Hmmmm Lamp dimmer or Mic amps[:o)]
I am with ddff
If you are using the A&H Led Lamps, There is a round disk on top.
This will dimm the Led Lamp.
If you have an other version without a dimmer you can’t dimm ![]()
quote:
Originally posted by martijnIf you are using the A&H Led Lamps, There is a round disk on top.
Wait the console doesn’t have a dimmer!?!?! That’s crazy, there’s two sized headphone outs and no lamp dimmer?
It’s not that big of a deal… I’m just shocked I’ve never used a console with a lamp port but no dimmer
Are there so many consoles with internal lamp dimmer? From the 10+ consoles in my rental stock only APB Dynasonic has this feature. And A&H lamps are lovely anyway- you can dim them seperately.
ddff
quote:
Originally posted by ddff_lvAre there so many consoles with internal lamp dimmer? From the 10+ consoles in my rental stock only APB Dynasonic has this feature. And A&H lamps are lovely anyway- you can dim them seperately.
ddff
At least the M7 and LS9 have built-in dimmers. Most of the analogue Midas i’ve used have them too. Not sure about others; I also come from the world of lighting, and every lighting console has them. Maybe it’s not as standard as I thought
Again, not a big deal, just surprised
you have a A&H why mix on anything else!
LS9 or M7 WOW
Glen Clark,
T112, iDR48
The Church At Covington Front Of House
Because its not actually mine I just get to use it. And I like to be well versed in whatever might show up on my doorstep for a show
quote:
Originally posted by tcacfohyou have a A&H why mix on anything else!
LS9 or M7 WOW
Glen Clark,
T112, iDR48
iDR-48, T-112, Mixpad
College
