Hello it be god to have dinamic eq. and multiband comp. in the sections of the channels, instead of count as fx. ![]()
Bye
Bye
+1.
I reckon that a limited amount of instances would be available due to limited processing power.
Sergio and Woutert, you know you can insert the effect directly on the channel’s signal path, right?
Of course you can - but still it take an FX Slot.
I would prefer kind of Digico Style.
the other way would be to add more FX slots for this
or to make it possible to use all 8 channels within the FX slot as separated inserts
Just make the D-esser a fully functioning Dyn. EQ. For most applications that would be perfect.
“Just make the D-esser a fully functioning Dyn. EQ.”
I’m sure a fully functioning Dynamic EQ takes more DSP than a De-esser. It all comes down to how much processing is available. I’d be willing to spend some money on a DSP upgrade so that my board (or IDR) could handle added features.
-Mark
