Direct Out default rant
I’m very curious what line of thinking led to the “direct out” points on the SQ being post-compressor by default, and set to follow mutes. Especially when the global setting isn’t with the other global settings, but is on the routing page.
Because this behaviour doesn’t match what was common on analog consoles, and doesn’t line up with one of the more common use cases on a console: clean, unprocessed tap points for multitrack recording (which is a default patch, even). And of course, the default state isn’t documented in the Fine Manual and isn’t obvious on the console without poking at the settings. Since the default settings that follow mute and tap-off post-compressor can result in ruined live recording tracks if they aren’t changed, I’ll suggest that the settings be changed to “post-preamp” with all follow mute settings disabled.
And if you are using SQ consoles for live recording, let this be a lesson to always double check those settings when you are on a new console.
Probably the thinking was: everyone wanting to record unprocessed inputs uses tie lines
Maybe you should dive into the manual before starting a rant? :man_shrugging:
Basically use tie lines for unprocessed recordings of the physical inputs, or Direct Outs for “processed” recording of the Channels… (or at least that’s my one-sentence summary of it). :slight_smile:
Of course, the file naming will be according to either the Input or Channel (depending on the method you are using), so if using Tie Lines, you just have to take note of what the mic was… But if you load the multitrack recording and play back on the SQ with an appropriate scene that matches the recording, the channels will be labeled in the mixer correctly.
I guess I’m not part of “everyone”, despite recording multitracks off of boards for decades. I always do it with direct outs.
It was just my thinking, this might have been the mindset behind their decision to implement it this way.
After many decades without having tie lines, I was happy to get this easy and streamlined solution on top in modern mixing boards . Sorry for you, if you feel left behind.
