Director quick patch?
Hi.
Is there a way to do a quick 1:1 patching in the routing Matrix? Patching 48 channels to 96 channels (2 x 48 for a digital split), patching tieline to recording, patching them back for VSC etc. is very cumbersome with this 1 by 1 patching, and makes for a fair amount of possible mistakes…! We had this on the ilive, at least fo input channels…?
Regards, Tor
+1million&1 for this…
If you use the ‘setup’ key to turn on ‘Only patch when the “Patch” button is pressed’ in the I/O screen, you can easily create 1:1 assignments by holding the on-screen ‘Patch’ button, and dragging diagonal or straight lines across the I/O matrix.
While you’re in those options, I find it useful to enable full screen mode for the I/O screen as well.
Hope this helps
  • Jeff, A&H
In director this works with the shift button being held down if you are not using a touch screen.
Awsome guys! Couldn’t find anything about this in the documentation :slight_smile:
I’ve not looked at the documentation, but it’s probably worth holding the ‘setup’ key while in a variety of the screens, to see what options are available for each one.
  • Jeff, A&H
