director rename show lost scenes
Hello,
i use my dlive cdm32 only with director (and MS) i renamed a show, loaded another show, went back to the renamed show and now i’ve lost some scene’s, the last one’s made in the renamed show.
can i find them somwhere on the director computer, i can only see the show in a tar format so i suppose the scene’s are in the tar.
regards.
There is no auto save for shows.
You need to save your current show if you need to keep the settings. If you rename something, you just rename the show that was saved before.
There is an override function that stores the current settings to the show.
Thank you steffen, but every time i started the pc with director i did have the scene’s, (without saving the show)so they had to be stored somewhere, any chance i could retrieve them somwhere from the pc?
also can you explain the override function a little bit more?
thank you
If you start director, it loads the last state of the console, this includes the settings, the configuration, the libraries, and all scenes.
But it does not recall a show or a scene by default.
For permanent use, you need to save a show.
This writes a copy of the actual state to the memory.
Renaming doesn’t affect the content of the actual show.
It just renames what was stored.
If you change a parameter, the last saved or recalled show has not the same content as the actual state any more and when you recall a show, the actual state of the console gets overridden with the content of the show, and the state before the recall is lost.
The same applies to a system without a surface.
thank you again, my loss.
