Hello colleagues! I have on avantis v1.3 firmware; I have this problem from previous versions, and it still persists; has anyone else encountered this?
why do all the channels in the layer appear as selected when I did not select them?
It seems that is the highlight option (when you touch a fader to show you what channels are moved) is permanently displayed.
I’m new on Avantis Solo but Avantis faders are touch sensitive and you can calibrate 3 things : alignment, motors and sensitive.
Maybe do sensitive calibration.
Before you can also deactivate the highlight option to confirm.
On a similar topic - has anyone experienced less or none of the laggy / freezing GUI / touchscreen issue with recent updates? I’m on the fence on buying an Avantis Solo, but in the past I’ve experienced lag when there’s a lot of D-pack plugins in use on the full-sized version.
