You can select the bottom of the screen to display the PEQ. The main PEQ screen also shows the HPF/LPF curves. It would be useful to see these in the display at the bottom of the screen.
+1, would love this
There is a clear display for HPF and LPF on the left side of the main window. I find this very clearly solved.
Not for people running surface-less…
It’s the same on surfaceless setups…
as alrady mentioned many times before… the south area needs more views ![]()
+1, while not a NEED, it would definitely be cool! I’d also love a way to see AMM meters or something down there…
OK, I would also like a display of the AMM meters here.
Good idea!
But that already exists ![]()
