dlive DM0/Director not storing scenes correctly
I’m using a DM0 with dlive Director v1.98. When I adjust fader levels and store it, everything is fine. The issue starts when I reconnect to dlive Director the next day, and some of my channels lost all of my levels and all of the faders are completely down at negative inf. I also have the same issue with routing my channel to the main outputs. The only recall safe filter I have is for the main output.
Has anyone else run into the same issue? How did you fix it? Do I just need to get a new DM0?
Sounds to me like Director is set to push its setting to the MixRack instead of the other way around.
Hi Dave, thanks for your response. I do make sure to pull settings from unit when I sync up
Is the DM0 being restarted in between Director sessions and if so, is there a Startup Scene set?
Also make sure no other devices are connected on the same network that could potentially interfere with the settings, such as iPads etc.
