dLive dropping audio Dante-Virtual sound card-logic pro
Hi! so I’ve been using dante to record to logic for the past few months and its worked great. however last couple weeks its been dropping audio for up to ten seconds at a time throughout worship set.
My set up is dLive CDM48 fitted with 128X128 Dante card, goes to switch, then goes to mac mini, through Dante virtual soundcard to logic pro.
Anyone had similar issues? what was a fix?
Hi Dima,
Sorry to hear you are having trouble with this.
If this is still an issue, please submit a ticket to support@allen-heath.com along with any videos/show files and details of your set up and the audio drop issue.
Kindest Regards,
Nicole
Hope this was resolved. If not though… have you checked your clock settings in Dante Controller? I’ve seen this kind of thing happen if clock is having trouble being resolved. (Typically in systems where two or more devices are competing for grandmaster.) Generally speaking you want your CDM48 to be the “master,” clock. Make sure “Enable Sync to External,” and “Preferred master,” is selected for the CDM48, and you should be good to go.
