hey guys,
i´m puzzled about some dLive Network Issues.
I have a S3000 + DM 48 Stagebox and a C1500. I use the S3 + DM48 in our Venue all the time. Standard network configuration + 1.98 Firmware on all the devices.
Couple of days ago i installed 1.98 on the C1500 and it worked like a charm with the DM48. Then i used the S3000 again, worked…
Then i tried to connect the C1500 again and it did not find the DM48. Same CAT, same place. The DM48 took a while to boot up and i thought…mmh looks like DHCP. Didn´t turn that on. But somehow, DHCP was turned on the DM48. All lot of people work on this system, so…
DHCP was turned ON the S3000 as well, but not on the C1500. So i turned DHCP OFF on all the devices. Trouble is…
The S3000 will start with the DM48, but the C1500 will not, when i switch them back and forth to the stagebox. Same IP Config, no DHCP, same firmware, same CAT.
I tried to reset the C1500 + i installed the firmware again. Thing is, when i turn DHCP ON the C1500 Surface, then after a time the DM48 will connect. DHCP is OFF on the DM48.
I´m not quite the IT guy, but i´m confused. Maybe some insightful user can help me out. I´m always sure the problem is me… in front of the screen, but not i´m running out of ideas. Maybe this behaviour is normal, but then i don´t understand it. Why is the S3000 working and the C1500 is not, with the same configuration and the C1500 will connect just when i turn DHCP ON on the Surface.
Just to be clear, i switch between the 2 Surfaces and not connect them both at the same time the DM48.
Thanks so much for you help.
Cheers Alex
