dLive Parametric EQ Translation
I thought that I’d share my findings with the seemingly cryptic parametric EQ values that A&H uses. The user manual declares the bandwidth value to be in octaves, but it’s not the same standard that many other systems use. The following table converts the A&H parametric EQ bandwidth (BW) value to the more common Q and BW values according to https://www.w3.org/TR/audio-eq-cookbook/. (approximate conversion)
Parametric EQ Translation:
A&H BW Std Q Std BW (octaves)
1.5 0.367 3.22
1.4 0.393 3.06
1.3 0.423 2.90
1.2 0.458 2.72
1.1 0.5 2.54
1 0.55 2.35
0.95 0.579 2.26
0.9 0.611 2.15
0.85 0.647 2.05
0.8 0.688 1.95
0.75 0.733 1.84
0.7 0.786 1.73
2/3 0.825 1.66
0.6 0.917 1.50
0.55 1 1.39
0.5 1.1 1.27
0.45 1.22 1.15
0.4 1.38 1.03
1/3 1.65 0.86
0.3 1.83 0.78
1/4 2.2 0.65
0.2 2.75 0.52
1/6 3.3 0.44
0.13 4.23 0.34
1/9 4.95 0.29
Shelving EQ Translation:
Shelving Type A&H Freq Center Freq Std Q Std BW
Low f f * 2.5 0.471 2.67
High f f / 2.5 0.471 2.67
Note that the shelf slope Q is a fixed value and not variable. Many of us wish that A&H will someday add that missing option.
Yeah, can we please switch to standard q values, at least as an option. :face_with_peeking_eye::grinning_face_with_smiling_eyes:
UPDATE: Unfortunately, I can’t edit my original post above after realizing that the dLive PEQ uses a dynamic Q which depends on the magnitude of the boost or cut. That table assumed a boost/cut of about 10.6 dB.
My revised estimation of the relationship is as follows:
  • Peaking:
    Q = (0.0008 * dB * dB + 0.0004 * |dB| + 0.45) / BW
  • Low shelf:
    Center frequency = f * (|dB| * -0.07 + 3.34)
    Q = |dB| * -0.0045 + 0.5254
  • High shelf:
    Center frequency = f / (|dB| * -0.07 + 3.34)
where:
  • 'BW’ is the A&H bandwidth value on the console EQ band.
  • ‘f’ is the A&H frequency selected on the console EQ band.
  • ‘dB’ is the magnitude of the boost or cut (in dB).
And, to add to that, in Mixing Station we find:
A&H BW Mixing Station
1.5 0.3
1/9 4.3
Being that Q changes depending on the current boost/cut, here are some scenarios using the formula above:
@ +/- 3dB boost/cut:
  • A&H Std Q Std BW (octaves)
    1.5 0.31 3.6
    1.4 0.33 3.5
    1.3 0.35 3.3
    1.2 0.38 3.1
    1.1 0.42 2.9
    1 0.46 2.7
    0.95 0.48 2.6
    0.9 0.51 2.5
    0.85 0.54 2.4
    0.8 0.58 2.3
    0.75 0.61 2.1
    0.7 0.66 2
    2/3 0.69 1.9
    0.6 0.77 1.8
    0.55 0.84 1.6
    0.5 0.92 1.5
    0.45 1 1.4
    0.4 1.2 1.2
    1/3 1.4 1
    0.3 1.5 0.92
    1/4 1.8 0.77
    0.2 2.3 0.62
    1/6 2.8 0.52
    0.13 3.5 0.41
    1/9 4.1 0.35
@ +/- 9dB boost/cut:
    1.5 0.35 3.3
    1.4 0.37 3.2
    1.3 0.4 3
    1.2 0.44 2.8
    1.1 0.48 2.6
    1 0.52 2.4
    0.95 0.55 2.3
    0.9 0.58 2.2
    0.85 0.62 2.1
    0.8 0.65 2
    0.75 0.7 1.9
    0.7 0.75 1.8
    2/3 0.79 1.7
    0.6 0.87 1.6
    0.55 0.95 1.5
    0.5 1 1.3
    0.45 1.2 1.2
    0.4 1.3 1.1
    1/3 1.6 0.9
    0.3 1.7 0.82
    1/4 2.1 0.68
    0.2 2.6 0.55
    1/6 3.1 0.46
    0.13 4 0.36
    1/9 4.7 0.31
@ +/- 15dB boost/cut:
    1.5 0.43 2.9
    1.4 0.46 2.7
    1.3 0.5 2.6
    1.2 0.54 2.4
    1.1 0.59 2.2
    1 0.65 2.1
    0.95 0.68 2
    0.9 0.72 1.9
    0.85 0.76 1.8
    0.8 0.81 1.7
    0.75 0.86 1.6
    0.7 0.92 1.5
    2/3 0.97 1.4
    0.6 1.1 1.3
    0.55 1.2 1.2
    0.5 1.3 1.1
    0.45 1.4 0.99
    0.4 1.6 0.88
    1/3 1.9 0.74
    0.3 2.2 0.67
    1/4 2.6 0.56
    0.2 3.2 0.45
    1/6 3.9 0.37
    0.13 5 0.29
    1/9 5.8 0.25
Therefore, choosing a value that is independent of the gain and thus constant is actually more correct than the often-used Q.
Mixing Station, by the way, refers to approximately half of the possible gain, namely 8dB, at which the Q values ​​are correct.
From a user perspective, yes, it is easier to grasp. However, knowing the actual Q used by the console can be useful. For example, I’ve written an app that can calculate the sum of multiple cascaded PEQ’s and predict and compare the results offline. This is helpful for when I’m using a channel PEQ which then routes to downstream PEQ’s found in groups and buses. With this, I can confidentially modify the collection of PEQ’s offline to be more efficient after inevitably playing whack-a-mole in live situations with feedback sensitive speaking mics.
Heya, did these equations came from measurements of a physical dlive unit or from looking at director / mixing station? And do you by chance happen to still have any of the original data/measurements used for these equations?? I’m scouringgggggg the net for info!
Sorry, those were just estimates based on the Director software graphical interface. I haven’t performed any actual audio measurements to confirm.
