Connect the RJ45 of the sennheiser port to my network dLive, G3/G4 is on the same range of my dLive, tab the sennheiser apply for detection, find nothing, even when i type the ip address manually. Someone has the same issue?
The WSM app runs on the computer in the same netwerkport of the dLive and recognize all the receivers…
It could be problematic to run the WSM at the same time. I struggle with the same problems from time to time. But I’m not really sure what fixes my issues now and then.
I haven’t set this up before, but I have heard that if you weren’t on the latest firmware for the Sennheiser, it wouldn’t work. I assume you’ve checked that?
Thx! I did a firmware update of the Sennheiser, it didn’t work. Today, i did the startup and everything is online… happy but a little bit confused.
Yeah, I know what you mean.
Can u explain how to setup the sennheiser to dlive?
