Or are the inserts not included in that limit? Also, can we save insert setups in the Library?
what do you talk about?
there is no 48 input limit
the limit is with the processing strips
48 processing inputs that can be connected to
8 FX return strips
mixes: 12 mono/stereo mixes, stereo main mix, 4 FX sends, 3 stereo matrix mixes
Ah ok, thanks. So inserts dont use processing so they are limited only by the amount of IO I have?
why are you asking for inserts?
the important things on the SQ are the built in processing
don’t get the point
He’s probably planning on using inserts across many channels for something like MultiRack or SuperRack.
With that said, you could have an insert point on all 48 channels.
Those insert points can be over any protocol (USB interface, option slot, physical I/O, etc) and do not change your amount of available processing channels (which is 48).
I have lots of gear that can be inserted. Thats why I’m interested in inserts rollseyes
Thanks for the concise, helpful and polite response ianhind.
Thanks for nothing Steffen.
