Does Allen and Heath QU24 have DAW control set up for Adobe Audition?
Hello everyone,
I am new to the Allen and Heath mixer and I must say it has been awesome using it. I use Adobe Audition CC as my DAW but I can’t am not able to set up DAW control with Adobe Audition. I see there is set up for other DAWs like Pro tools, reaper, logic, Ableton live. Does Allen and Heath not have DAW control setup for Adobe Audition CC? Is there a way to go about it?
There is a separate Forum section specifically for DAW issues. Try posting there.
I haven’t tried it yet, but it looks like all you need to do is install the proper DAW Control Driver, (maybe the Mackie protocol) from the A&H website. https://www.allen-heath.com/key-series/qu-series/#tab5
And then go to PREFERENCES within Audition and choose that protocol. This video should offer some help. It is for version CS6, but version CC should be basically the same because it followed CS6. https://www.youtube.com/watch?v=eKT20GmFS1E
Hope this helps.
Hi Gordon,
Thank you so much for your response. I have tried it using Mackie protocol on windows and it did not work. I have done it exactly the same way you advised but it is not working. I used another DAW (Reaper) and it worked flawlessly. I also checked through the Allen and Heath link (https://www.allen-heath.com/media/DAW-Control-Setup-Notes-V1.40.pdf) and they don’t have set up notes for Adobe Audition CC.
Thank you so much for your time.
Franklin
