Is there any reason why I shouldn’t attach both the DSnake & Ethernet connectors on the QU16 to an Ethernet switch, then run one CAT5E cable to the another switch with an AR2412 & Wi-Fi access point attached so that I can rack the WiFi AP that I use with the iPad and the AR2412 together - but still only need to run one cable?
I know that the iPad remote is just using standard TCP/IPV4 - but what about the DSnake? can they co-exist on the same physical network?
Thanks…
According to:
https://allen-heath.helpserve.com/Knowledgebase/Article/View/703/122/dsnake-can-i-run-dsnake-through-a-switch
it looks like this is possible with switches that support tagged VLans (using a VLAN dedicated to DSnake & one for the network traffic)…
Now to find some appropriate switches to test the theory…
I don’t see that this would work. The two things work on different protocols. The DSnake is proprietary. It may work through a switch but not sure why you need it if the iPad router does not. The router has to be connected to the network port.
According to the knowledgebase article DSnake uses Ethernet OSI layer 2, same as TCP/IP - it’s only at layer 3 the two diverge.
(OSI model - Wikipedia for more on OSI layers).
A tagged VLan is a way of running multiple virtual networks across the same physical cables/switches as if they were completely independent.
So assuming a switch that supports tagged VLans on each end of the long Ethernet cable that runs from the front to back of the room ports 1 & 2 on each switch can be set to be completely independent networks - as if there were actually 2 wires running down the room.
It’s essentially multiplexing a number of Ethernet connections…
Ok - it’s been a while but I’ve eventually got round to testing this - and indeed it is possible to run both a data network (for iPAD control etc) and D-Snake down a single CAT5e or CAT6 cable between the stage and FOH position.
You need 2 managed layer 2 switches that support V-LANS. I used two TP-Link TL-SG108E switches, but the 5 port version TL-SG105E would be fine and a bit cheaper (both are very good value). You also need a Windows PC connected to the switches so you can run their configuration software.
I setup port 8 on both routers as vLAN #8 and used it for D-Snake.
I setup port 7 on both routers as vLAN #7 and used it for data.
(You can use any port for each of the two networks, and you can add more ports to the data network if required)
Next: Setup the routers to limit connections on ports 8 & 7 to 100MB full duplex. And set the port based QOS (Quality of service) to give ports 1 & 8 maximum priority, port 7 low priority.
Port 1 of both routers were connected a CAT5e cable
On the FOH router I connected port 7 to the data network connection on my QU16 and port 8 to the D-Snake connector.
On the stage router I connected port 7 to a WiFi router (that the iPad connects to) and port 8 to the AR2412
The result - a rock solid audio connection (tested for quite a while without any glitches) and a good iPAD connection to the desk.
You could also add any managed amps or speaker controllers in the stage rack to the data network, and add a PC/MAC to the data network at FOH to control them.
If anyone would like more details on how to set this up please shout & I’ll add screenshots etc. from the router setup.
Ok it works but I’m wondering why do you want to do it that way. I mean, a good router next to the mixer gets the job done and you still only have one cable to run to the stage and need less gears = less potential problems. The only advantage I see is more data connection if you need them on the stage.
I agree that often just putting a router by the desk is the simplest & best option. But having the router at the front can sometimes be a better option, and in that case just running one cable is nice. Some examples:
I recently did a corporate gig where the desk had to be in the projection room and I was using the iPAD to make changes in the room - In this case I wanted the router at the side of the stage on the top of the amps/radios/AR2412 rack.
In a large room with a lot (or unknown amounts of) WiFi I’d rather have the router to the side of the stage than FOH for the same reason I put the radio receivers there - I want to be sure of a good signal on stage (where I need the iPad).
If I have a rig where there are devices in the rack on stage that can be remote controlled over Ethernet. E.g. amps or radio receivers, I can wire those into the data network and connect a PC/mac at FOH to control them - while still only needing one cable between FOH and the stage.
So - it’s really a case of knowing the options and picking the best one for a particular gig
And if you leave a couple of switches set up in a bag with your kit then it’s not hard to slot them in when needed.
Have to admit I liked that idea, just changed my setup and it seems to work pretty robust (50m cable). I’ll keep the more complex setup and see how it operates in live situations.
Thanks for pointing this out!
One of the switches could even be the WAP so there is only the one extra switch to care about - you could even have two the same, have WiFi available at both locations
Fix the channels differently (and pref. non overlapping), use the same SSID and key and you’ll roam seamlessly between them.
Unfortunately I don’t know of any managed layer 2 switches with built in WAP (Wi-Fi adapter) - all the wifi routers I’ve used work at a higher level…
But if somebody does know of one then please let us know
Andreas: glad I could help
Please let us know how you get on with the setup. Though for the sake of paranoia I’d make sure I rigged it so it was easy to patch directly from the desk to the AR2412 if things all started going wrong at soundcheck!
Don’t hear about managed switches within a WAP either, and separating VLANs really is mandatory. Of course I’ll be prepared to switch back, I’m paranoid in a similar fashion…
Era, pepwave kit will do it, but they’re serious budget (more than a QU16!)
I’ve not looked for vlanning waps - I have used pepwave kit (borrowed from work) though…
Probably anything supporting dd-wrt would do the job.
since the proposed layout costs around 75 Euros I personally don’t mind to not have switch and WAP in one box. But I could afford carrying additional spare units, just in case…
dd-wrt? thought thats router software, nothing to configure specialized switch hardware (VLAN switching can’t happen on software level, its simply too fast)…
Some of the dd wrt routers can deal quite happily - the draytek hardware in particular springs to mind.
Of course it’s significantly cheaper to just have a couple of “normal” WAPS and a couple of ~5 port L2 managed switches…
yup, you’re right in all points. For example the Vigor2130 seems to have all required functionality (among plenty of stuff not required), but a single unit costs about twice the three box solution and seems to be even more complicated to mount inside a rack…
Well there you go then.
I’ve recently used some pepwave kit which has the required function and would be trivial to rack mount (since it’s designed for it) I hadn’t really thought the single box solution through though
Let’s stick to three or 4 boxes as the solution (WAP at each end is probably a good idea) Could probably be mounted in a small case for each end (since they’d be identical it wouldn’t matter which one you grabbed for each end, or for a “small” gig). Would also allow easy mounting slightly higher than racks, putting a WiFi aerial in the lid
Need at least 4 ports:
DSnake device connection
Cat5
WAP Connection
Ethernet device Connection
Only the ethernet device connection at the “stage” end would be wasted.
You could even put a wireless IEM transmitter in one, for PAFL out and about…
Hi there!
I made the same connection with two SG108E switches but I have some issues with crackling sounds on the audio.
Did anyone you experience the same problems?
For as far as I can see I did exactly the same as mentioned before…
kind regards,
Stef
