Hello, I recently purchased a new QU32 and AB168. Local connections work with no issues. That being said when I connect the AB168 nothing works. Board shows the dSNAKE as connected and all link lights are up. Specifically I am just trying to start with the L/R FOH signal out the dSNAKE. I get signal out directly from the board no problem. This is my first digital board. My understanding that the dSNAKE output map 1 to 1. Could my dSNAKE be defective? I can change the inputs later that I want to go through the dSNAKE. Right now I’m just using the STR3 input with some music. Any help would be greatly appreciated.
If you want to send LR to your AB168 you’ll need to assign L and R to one of the eight physical outputs. As indicated on your screenshot you currently only route Mix1-8 to your dSnake outputs (L/R would be 11&12, which are not available on the AB168).
