My system has been the recipient of two lightning strikes and two repairs in two years.
Since the lightning has taken out the Qu24 and AR84 both times, I suspect the 150’ copper
Ethernet cable going between the two that runs along the inside of the church opposite
the soffit as the potential culprit (or at least an enabler.)
I have found that there are Ethernet to fiber optic converters (probably normally used in a
manufacturing environment) such that I could establish the following for the dSnake
connection:
Qu24 — Ether cable — Ether to fiber converter — fiber cable — fiber to Ether converter — Ether cable — AR84
Has anyone used this setup or am I on a fools errand?
Yes, this is possible and there are many users that we’ve heard from who’ve set this up successfully
We cannot guarantee that you will be able to do this with all media convertors so would always recommend purchasing from somewhere that will allow returns.
You can find more information on requirements in the following articles:
(note that dSnake and DX are both layer 2 fast ethernet protocols. They have different channel count, sample rate and control messages, but have the same requirements for conversion/switches/fibre)
