Dual Mix Rack Configuration
Hello together,
as a new ilive user i have a problem with the dual mixrack configuration.
This is our setup: T112, IDR16 masterrack, IDR32 slaverack. The outputs on the slave rack are working.
How can i route the inputs of the IDR32 to a channel strip? I read that the Inputs of the IDR32 start on the Channel 65 (65 should be A1???). But how can i choose channel 65 in the preamp section?
The documentations from A&H arent really helpfull.
Thanks for telling me a way!
Greets
Jan
Hi Jan
when using dual Rack to use full control of the preamp (gain, Polarity, Phantom power) - input sockets from the master mixrack use channels 1-64 and input sockets of the slave mixrack use channels 65-128.
Once you have configured your system so that you are in Dual Rack mode you will have the ability to select channels 65-128.
You may need to assign these input channels to a channel strip on your surface layout. once you SEL a channel in the range of 65-128 in the preamp window there is a drop down box called ‘Source’ you will be able to select your slave mixrack & sockets here which will enable full control of the Preamp (gain, Polarity, Phantom Power).
Regards
Sam A&H
Hi Sam,
since nothing worked, i just build up the whole setup once again. Now erverything is working great, but dont ask me why now?!
Thanks for your help!
Best regards
Jan
