dual rack
I have a T112 with IDR48, I want to connect another IDR48 as Port B. Stage monitors would only be controlled by Ilive editor, no other console. What audio networking card connection is better? Modules used in each Micrack? I do not want to use ILive Editor using wireless, WiFi in happen to hang with control.
One Dante card in each of the IDR48 units and a gigabit switch between them should provide you with digital split and recording to a computer with dvs nstalled connected to the gigabitswitch. Laptop editor plugs straight into monitor IDR with ethernet cable. No wifi involved.
IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express
Sveiks, Gints!
Do you need dual setup in order to have more than 48 inputs on the system?
Most easy way to achieve this would be ACE card in one of systems.
If you’re talking about signal split FOH/ Monitors there are number of options- Dante, Madi, ACE. Regarding ACE, I’m not sure if you can solve split just by fitting card in one of iDR or you need pair.
ddff
You need a Pair of ACE cards to do a SPLIT system , or just one to do dual rack (expansion)on the T series - however this doesn’t offer a digital recording solution so either Dante or Madi is the best option.
Cheers
Richard Howey
Audio Dynamite Ltd
