Dual-Stage/Serial Compressor
I’m a big fan of the Allen & Heath SQ and SQ+ series and love how powerful and intuitive these mixers are. However, when mixing live, I often find myself missing a feature that I rely on heavily in my DAW: the ability to use multiple compressors in series on a single channel.
In my DAW, I almost always use two compressors on vocals: one slower RMS compressor to smooth out the overall dynamics, and a faster Peak-based compressor to catch the transients. This combination helps me achieve that consistent, polished vocal sound I’m after. On the SQ, though, I’m limited to just one compressor per channel (unless I route through a group or use a MultiBD4 insert, which are both limited in number). As a result, I sometimes struggle to get the same level of control and consistency, especially for vocals.
I know that with the Avantis or dLive, you can apply dynamics at two points per channel, but unfortunately, this isn’t possible on the SQ range (which I totally understand). That’s why I’d love to see a dual-stage or serial compressor as a new DEEP plugin for the SQ. Imagine a single compressor plugin with two independent stages, each with its own threshold, ratio, attack, release, and RMS/Peak detection mode. Essentially, it would be like having two compressors in one; giving us the flexibility to dial in that perfect, layered compression sound without workarounds. With the larger screen on the SQ+, there is enough space for the controls needed for this compressor.
I think it would be a game-changer to achieve studio-like vocal (or instrument) consistency on the SQ platform.
Just an FYI - the Avantis and the Dlive have two insert points per channel (vs the SQ’s single insert point), but like the SQ series they only one dynamics processor per channel. Of course there are more Dyn8 instances available in both of those platforms that you can insert in one/both of the insert points, but overall their functionality is very similar to the SQ.
I wasn’t aware that the Avantis and dLive also only have one dynamics processor per channel. Good to know, thanks!
Maybe this makes this idea even more interesting, as it would give the Allen & Heath mixers a unique tool for achieving more refined dynamics control? I think a dual-stage compressor could be a valuable addition to the entire lineup, offering more dynamic control without requiring additional insert points.
Can you not use the channel compressor, and then another on the insert?
You cannot insert DEEP FX.
I am interested to know if there are others who also see potential in this feature: a dual stage compressor for better dynamic control, as part of the DEEP compressors. Similar to how hardware units like the 5046 OptoFET ​​or the Manley SLAM! work.
On a mono channel, you can use the compressor and insert MultiBD. You can dumb down a MultiBD if you want it to do something simple by setting all bands to the same parameters.
Additionally, you can send the vocal channels to a group and compress again there. If you want to get nuts, you can insert MultiBD on the group and send a vocal through 4 stages of compression.
