The system:R72/iDR32(Master)/iDR16(slave)
How could the input signal for iDR32(Master) route to iDR16(Slave) output?
I couldnot find out this way with as follows below.
Q[Can I use the outputs on the MixRack?]
https://www.ilive-digital.com/Downloads/Understanding%20Dual%20Rack%20Mode%20in%20iLive.pdf
Please tell me the detailed way.
Your advise would be appriciate.
On the Output menu on the console, you should have a drop down menu when the MixRack tab is selected.
You patch the outputs like you normally would. Just remember, you don’t increase your number of busses because of Dual Rack mode. You still have the same master busses, but now you can patch them out of the Slave rack as well.
edited for accuracy.
take care
Gil
Gil Parente
Design & Integration
Entertainment Arts, Inc.
Thank you for your advice.
Everything is working.
