Ducking on QU 16
Trying to figure out how I can duck music on ST1 input, using two mics is that possible with the QU-16 mixer.
thanks
read the manual
a quick search in the PDF will lead you too the ducking page
https://www.allen-heath.com/media/Qu-Mixer-Reference-Guide-AP9372_10.pdf
Thanks I have read it a a bunch of times. I assume I’m not understang the gang mode. I’ll mess around and see if i can figure it out.
Gang mode is having the trigger source control the ducking of levels in more than one channel.
You want to do the opposite, have two input channels duck a signal play back channel.
Do you have the channel insert selector set to ducker.
I’m afraid you have to use an aux as the trigger source if possible
I guess I could hook the mics up to another mixer, then route 2 auxs sends from mixer 1 to the QU-16 and then use that channel as the trigger. I’ll try that.
thanks everyone.
Like Steffen suggested select an open mix to be the trigger source and then bring up those two mic channels in the selected mix for the trigger. I would go post fade for that mix.
This is how you do it. 1) Use a group and add only the two MIC channels to that group with their faders set at unity (0). 2) Set the group’s fader to unity (0). 3) Remove the group from the main LR mix by selecting the LR mix and turning the group off in the MIX display. 4) Select the ST1 channel and turn the Ducker/Inset switch to ‘Ducker’. 5) Switch the ducker on with the ‘Ducker’ button. 6) go to the Ducker screen and select ‘Grp 1 L’ (or whatever group you used) as the Trigger input. 7) Adjust the depth value to how much you want it to duck. Done :slight_smile:
