In DX168 redundant mode can I connect to two SQ6 mixers(FOH&Mon)?
Hi Joseph,
No - it is not possible to connect two consoles to one expander.
An expansion unit expands the console’s i/o, you would then need to use a system to system connection to share audio between the two consoles.
Cheers!
To further clarify what Keith is saying: to properly split to two sq consoles either you need to have two separate dx units with an analog split, connect the two consoles together through the slink port, or when it FINALLY hits the market get an slink option card so that the dx will feed one console then get passed to the second.
