With our Avantis can we plug in a GX4816 into our DX Hub?? We have 2x DX32 in the hub currently but need more I/O.
@Jonproaudio
The DX Hub has 1x GX/gigaACE port for connection to a console. This carries 128x128 channels at 96kHz.
The hub then effectively breaks this out into 4x DX ports, each of which is 32x32 channels at 96kHz for connection to expanders.
The GX4816 also has a GX/gigaACE port for connection to the console, so no, it is not possible to connect this to a DX Hub.
However!
The GX4816 is actually like an expander with a smaller DX Hub built-in, or maybe a DX Hub with analogue I/O added… You have onboard sockets, plus 2x DX ports.
So you can lose the DX Hub from the setup, have one connection to the console to the GX4816, then connect each of your DX32’s to the DX ports.
More info on GX and DX systems can be found here - https://www.allen-heath.com/media/DX-GX-System-Guide-ISS_5.pdf
Hope this helps.
Thank you Keith. This is amazing news!! Thank you for your knowledge!
I forgot we have a DX012 that we use for 3 AES outputs, to send signal to our amps. So that throws a wrench in using the GX4816 as the hub (sad face) sorry about that.
