Been having connection issues since new firmware 1.81 (May not be related to firmware)
I connect my laptop direct to iDR via ethernet port.
System log reads two connections with the same ip address (192.168.1.10), shows my loop back ip address of 127.0.0.1.
I will get disconnected from the mixrack after a period of time, and when I go to reconnect, the mix rack does not show up to choose, unless I exit out of Editor and restart the application.
Trace error messages in the log file;
***** TraceError message repeated:116775 TraceError message:- mSourcePath = “192.168.1.3/FX Manager 03” mDestinationPath = “FX Unit IO Mode Monitor” mSourceParameter (PARAMETER_BASE Adjusted) = 0 mDestinationParameter (PARAMETER_BASE Adjusted) = 2 mSyncToSource = true mBidirectionalLink = false mRemoveLink = false mRequestingClass = Null mCallbackInterface = Null (ciLiveManagerBase.java:256)</
I do have two Java programs. Update 18 for (64bit) and update 25. Wondering if this is related.
Anyone gone through a similar problem?
Cheers!
CRJ
Oswego, IL
T112 & iDR48
Sony F 1.73GHZ I7 8 Core
Win 7 Pro 500GB HD 8G RAM
TP-Link WR1043ND
Airport Extreme & Express
Dante May?
More info on this;
I removed both Java installations on laptop and reinstalled the latest version (update 25 for 32 bit). No improvement.
When my laptop is connected to the iDR48, The surface link shows the following;
No lights illuminated in status.
Net Bridge off.
Red X in surface lock.
Disconnected laptop and turned off.
Established Ace connection between T112 surface & iDR 48, everything normal.
Booted laptop, connected to iDR via ethernet and started Editor.
Editor goes through normal start up process, however I noticed on the T112 surface that during the time when Editor is loading, the status light changes from green to no lights illuminated and the net bridge green check disappears…? The Net bridge check actually comes on and disappears in 2 second intervals along with the status light going green then disappearing until editor is finally established on the laptop. After Editor is fully loaded and displayed, the T112 status lights are back to normal, however in Editor- no light is illuminated in status, net bridge is off, and red X in surface lock.
System log on T112 shows two duplicate ip addresses from laptop connected, one second in time apart.
This did not happen in 1.80 or prior, and I have made no system changes on laptop.
Certainly in need of any suggestions or input.
CRJ
Oswego, IL
T112 & iDR48
TP-Link WR1043ND
Dante May?
I am not too keen on dchp after a few incidences with duplicate ip addresses. I am leaning towards static ip addresses now. You can avoid the whole ip conflict thing with static ip addresses for each thing on the network.
112T/IDR48/IDR16
Everything here is static, and no routers are being used.
No DHCP enabled on the iLive system.
Mix Rack is 192.168.1.3
Surface is 192.168.1.4
Touch Screen is 192.168.1.5
Laptop is 192.168.1.10
default gateway is 192.168.1.1
Surface to iDR is Ace.
Laptop to iDR is direct to the ethernet port.
CRJ
Oswego, IL
T112 & iDR48
TP-Link WR1043ND
Dante May?
Is your WIFI activated on the laptop?
SRV-AVB
R-72, iDR-16, xDR-16
quote:
SRV-AVB
No, WiFi is disabled on laptop.
Only connection that is active is the lan port which is connected to the iDR48.
It would be nice to see more specific connection information on the iLive log, like mac addresses for example.
I connect my laptop to my switch at home, and it only shows one connection, so this is really troublesome.
CRJ
Oswego, IL
T112 & iDR48
TP-Link WR1043ND
Dante May?
Strange. Updated to 1.82, still same issue.
I did notice that there are two ports 49175 & 49176 running, on javqw.exe
Must be Java related.
CRJ
Oswego, IL
T112 & iDR48
TP-Link WR1043ND
Dante May?
