Editor faster on windows! Why?
Is it just me who is experiencing Editor slow on OS X than on windows.
I have tried both 10.6 10.7 10.8 on three computers, but no improvement.
The SuperStrip can take up to two and half seconds to update.
And if i am too (quick?) on the select button the “systems busy” pops up.
Should it be like this? or have I missed any configuration in mac os x.
Any help would be nice - thanks.
/Mikael
Well Editor runs in Java, so make sure you have an up-to-date version of JRE. It should have nothing at all to do with Editor.
/Mikael
iDR-48, T-112, Mixpad
College
Hello tk2k
JRE is 1.7.0_9 I think is the latest.
So you do not have these difficulties?
Are you using mac?
/Mikael
Quote:
honestly java is not rock’n roll and I hope urgently the “New” editor 2.0 is without java. Try Java 1.6
i am on Mac.
Torsten
Hi Torsten.
Tried the 1.6 but no improvement.
I have put together a short film to demonstrate the difference:
it is almost 3 seconds difference between windows and os x.
should it really be like this?
Do you have the same latency?
/Mikael
quote:
i am on Mac.
Torsten
It may have something to Do with Apple not supporting Java since, like, 2010 or so. Steve Jobs didn’t like it.
Java has been sub par on MacOS for some time and may be sub par for some time.
But your performance is a bit too bad.
/Mikael
Christian Tepfer
Hamburg, Germany
"Do you have the same latency?
/Mikael"
Hi, Mikael,
no chance from here to say right or wrong.
i think that java is not fault for the delay.
and yes i have sometime latency on this when its get hot around… but i think it is not your problem solver.
good luck, Torsten
To be honest I’ve never had a problem. It always seems fast enough
College
Hi Torsten.
/Mikael
i am on Mac.
Torsten
Experiencing the same lag on my system, I am really annoyed with all those “system busy” messages even though there is no audio going thru the system, no meter activity and just a surface and one wired editor session … very lethargic response from the mac’s editor window… in v.1.9
RayS
R-72/iDR32/iPS10
