Effects Discussion
I have been working with the delay and reverb on the Qu-32. Does anyone have any settings worked out that you like?
On almost every effects unit I have ever worked with (guitar rig, FOH unit) the factory settings are almost unusable.
Why does the delay effect have linking capabilities but no RIGHT offset? You have to manually select one side or the other and offset the ms by hand… How about an offset that tracks with tap tempo? That is the only way to maintain the stereo image.
The reverb has a high pitch flutter going on that very unnatural.
I would love to start some discussion on the qu effects so we can trade and learn from each other. Plus any EQ-ing that needs to be done…
Also, does anyone know if a document exists that explains all the effects parameter settings?
Hello!
Let’s start discussion, it would be nice to hear what other users are using.
I mostly use Reverbs, my favourite is Hall massive. Of course I make adjustments: shorten it to 2s, Lowcut to 150Hz, Highcut to around 5kHz. For my kind of music it works great, it’s meant to full music a bit and places between phrases, I don’t want to have it too dry. There are a lot of parameters in ‘expert’ section, I used to play with them and see what it does to sound.
Keep in mind that the Reverb has more algorithms
play with them to find the best reverb for the signal
mostly I need a mono delay with one or two taps, so I’m happy with it at the moment, but would love to see the improvements from the GLD
btw. would love some vintage reverb as well, to add more flavour
I too found the reverbs to be a bit more fluttery than the ones on the GLD. I found that you go to the page in the extended part and I think it’s Diffusion. It defaults to 12. Raise it to 20. That takes out those flutters. I also lower the low cuts. I don’t like verb rolling off at say 180. I like it down below 100. More natural. More like my old Lexi 480 box. Beyond that it’s just pre delay and RT.
I think an effects parameter settings document (data base) that Dr. J talked about would be of great benefit for me, as I am new to the Qu-16 and effects settings in general. I have found the factory settings not as “spot on” as I would have liked, and I know they are just a place to start, and will need personal tastes applied. Here are a few on reverb that I have begun to try.
TYPE
Hall and Room are self-explanatory. Plate emulates the plate reverbs common in the ’60s, which were often used for vocals. Inverse creates a reverse reverb effect, where the reverberation starts at a lower level and increases to a higher level. Spring types emulate old mechanical reverbs known for a “sproingy,” metallic sound. Gated reverb has a decay that cuts off abruptly below a certain level. Convolution reverbs load a sample (also called impulse) that defines a room’s characteristics, and impresses these characteristics on the signal being reverberated.
ROOM SIZE
Larger sizes typically correlate to longer reverb times and possibly a wider stereo image. As even synthetic rooms can have standing waves, if the reverb sound has flutter (a periodic warbling effect), vary this parameter in conjunction with decay time (described later) for a smoother sound.
EARLY REFLECTIONS LEVEL
This parameter sets the level of the first group of echoes that occurs when sound waves hit walls, ceilings, etc. These reflections tend to be more defined and sound more like “echo” than “reverb.” Prominent early reflections tend to work better with sustained sounds, such as vocals and pads, than percussive sounds. Balance the early reflections so they are neither obvious discrete echoes, nor masked by the decay. Lowering the early reflections level also places the listener further back in the room, and more toward the middle.
PRE-DELAY
Simulates the amount of time it takes for a sound to leave its sound source and create a first reflection. Setting a slight pre-delay offsets the reverb from the dry signal, which can prevent reverb from “stepping on” the signal being reverberated. Also, increase pre-delay to give the feeling of a bigger space; for example, large room sizes tend to work well with significant pre-delay.
DECAY TIME
This determines how long it takes for the reflections in the room to run out of energy. Long reverb times may sound impressive on instruments when soloed, but rarely work in an ensemble context (unless the arrangement is sparse). Reverb presets often link the decay time and room size parameters so you don’t end up with, for example, a small room with a very long decay. However, “wrong” settings can sometimes create useful sounds.
DAMPING
With softer surfaces (e.g., a hall packed with people), the reverb tails will lose high frequencies as they bounce around, producing a warmer sound with less “edge.” If your reverb has an artificial-sounding high end, add damping to create a warmer sound. Damping affects overall tone, so setting it “oppositely” often works well (lots of damping with a bright-sounding song to warm it up, little damping if the song needs more “air”).
HIGH FREQUENCY ATTENUATION
This reduces the high frequencies going into the reverb. If your reverb sounds metallic, reduce the highs starting at 4–8kHz. Remember, many great-sounding plate reverbs didn’t have much response over 5kHz.
LOW FREQUENCY ATTENUATION
Use this to reduce low frequencies entering the reverb. This can prevent a muddy, indistinct sound that takes focus away from the kick and bass. Try attenuating from 100–200Hz on down.
WIDTH
Some reverbs allow expanding or collapsing the stereo image.
LOAD IMPULSE FILE
This is found only in convolution reverbs. A convolution reverb will not function without having a reference impulse audio file loaded.
MODULATION DEPTH
To create more variation in reverb sounds, modulation adds subtle changes to the reverb characteristics. Increase modulation depth if the reverb sound needs more “animation.”
MODULATION RATE
For reverbs with modulation, this determines the rate at which modulation changes occur.
EARLY REFLECTIONS DIFFUSION
Increasing early reflections diffusion pushes the early reflections closer together, thickening the sound. Reducing diffusion creates more discrete echoes. For percussive instruments, lots of diffusion avoids the “marbles bouncing on a steel plate” effect caused by too many discrete echoes. However, for vocals and other sustained sounds, reduced diffusion can give smooth reverberation that doesn’t overpower the source and maintains clarity.
REVERB DECAY DIFFUSION
This is similar to early reflections diffusion but affects the reverb “tail.” Many reverbs use a single control for both diffusion parameters.
REVERB DENSITY
Lower densities give more space between the reverb’s first reflections and subsequent reflections. Higher densities place these closer together. Generally, as with diffusion, higher densities work better for percussive content, and lower densities for vocals and sustained sounds.
HIGH FREQUENCY DECAY
With reverbs having separate decay times for high and low frequencies, this sets the decay of high frequencies. A longer high frequency decay gives a brighter, more ethereal type of reverb that can sound great on vocals as it adds more reverb to sibilants and fricatives, while minimizing reverb on plosives and lower vocal ranges.
LOW FREQUENCY DECAY
With reverbs having separate decay times for high and low frequencies, this sets the decay of low frequencies. A longer low frequency decay gives a bigger, more “massive” type of reverb that’s more like a large live space, but when used to excess, can give a “muddy” sound.
CROSSOVER FREQUENCY
This sets the dividing point between the high and low frequencies mentioned above.
MIX
Use this to edit the balance of dry and reverberated sound. If the reverb serves as an insert effect, set this for the desired blend. If the reverb is a send effect, this is usually set to reverb only, with the return control determing the overall reverb level in the mix.
GATE
For gated reverb, this sets the level below which the reverb tail is cut off. Using relatively high gate settings was a popular effect in ’80s synth-pop.
GATE DECAY
When using gated reverb, this adjusts how long it takes for the reverb tail to decay after the reverb signal passes below the gate threshold.
Great responses fellas… I will start my findings soon as I dig through the parameters…
In the iLive forum I saw where there was a file loaded that discussed all the details about the parameters and so forth but the link is dead… I get an error??
