A bit of a basic noob question here. What is the best way to send FX to monitors on the SQ5 when mixing both FOH and monitors from the same desk?
So let’s say VoxLead wants reverb in the FOH - I would set up reverb in say FX1 and send VoxLead signal post fader to FX1. I would then send FX1Return to FOH. If I pull VoxLead down in the FOH then the reverb goes down too. All good.
Let’s say that VoxLead, like many artists also wants some reverb in their monitor: Monitor1. One way would send FX1Return to Monitor1 as well. The problem with this is that whilst VoxLead is PreFader in Monitor1 their reverb on FX1Return in the monitor will vary with changes in the FOH level of VoxLead.
What else might you do- other than use seperate desks for FOH vs monitors?
I guess I could use the patch window to spilt the signal at the input socket to another spare channel VoxLeadMon and send from that (post fader) to another FX instance (FX2) and return FX2 to the monitor instead of FX1?
Is this what people do?
Thank you
