I’m looking for a nice method to use the Waves-plugins with IO-card in Auxes. The compressors and so on will be used as inserts. No problem so far, but if i want to use an AUX for delay, I have to use two Input-Channels for routing it back to Main. It would be cool, if in the 8 internal FX racks there is an empty Rack that could be used for audio passthrough. So I can use the delay over Waves as insert on an AUX and can use the FX-return from the internal rack for routing it back to main. So I don’t need to burn input-channels for that. Or is there another possibility to do that? I tried Master and Aux over Matrix, but that’s to complicated to adjust the return level in a fast way.
i thought on an own „passthrough“-FX choosable in the FX library which easily connects the FX in with the FX out. In the Aux the waves plugins are inserted. In the FX section i can choose this Aux for input. Do you think that‘s problematic? I even could use the FX PEQ
Hi Steffen,
But why is it possible to route the FX-Return to Physical Outs but not with the FX-Sends?
This structure makes no sense for me at least…
Ok maybe for recording the wet FX only…
that is not needed for FX since most of them will change time parameters anyway
if you need insert processing (EQ, Compression) then you can use the inserts already
