EQ channels over Aux bus
Hi all,
Just figuring out howto do some EQ over monitors. It seems that i only can EQ things on the Aux bus, but not on channels. Lets say i have a stereo in ear mix, and the singer wants the guitar to be EQ’d how can i do that? FOH EQ is no problem but EQuing instruments over Aux channels. kind regards,
Maarten Louer
Hi Maarten,
Let’s say you have an iDR32 mix rack. Even though you only have 32 mic pre-amps, the iDR32 still has 64 channels of processing power. So you can assign mic pre-amp 1 to channels 1 and 33, pre-amp 2 to channels 2 and 34 and so on. Use channels 1 to 32 for front of house and channels 33 to 64 for monitors.
Enjoy!
Paul
quote:
Originally posted by parsen
Hi Maarten,
Enjoy!
Paul
and don’t forget to set the aux source at least post PEQ of course :smiley:
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
Hi Woutert,
thanx for this usefull info. That i didn’t know :smiley:
So then i can seperate the FOH EQ from Monitor EQ. As it normally should be .
thanx, bedankt :smiley:
quote:
Originally posted by woutert
Hi Maarten,
Enjoy!
Paul
Wouter
Hi all,
Maarten Louer
Same way as you’d do it on analog console - Y split where one channel goes to PA, other unassigned from main mix, just to AUXes post EQ. The only difference here you don’t need to carry Y-cable with you.
ddff
Ok i did the follow.
Custom strip in Editor with two tabs. one FOH the other AUX
both with 16 channels with same names etc etc.
Now i’m able to EQ the instruments separately from FOH to Monitors.
But still i have one issue left to fix. Now i cannot Pan the instruments so the the
sterei in ear has a nice mix. How i can do that? hope you guys can help.
thanx in advance
Maarten Louer
Hi all,
Maarten Louer
You just make stereo AUX. That will have it’s own pan.
ddff
HI ddff,
I have allready a stereo aux setup (output 5/6) merged to one stereo fader with a panning knob, but how can i pan the guitars? or keyboards? I’ve setup channels 1 to 16 inputs and FOH mixing tab, and 26 to 42 as monitors (same naming etc etc) these channels have a blue preamp knob so that i have separate gain from FOH and Monitors, but then the panning does not work.
quote:
ddff
Hi all,
Maarten Louer
dear Maarten,
-I have allready a stereo aux setup (output 5/6) merged to one stereo fader- sorry i don`t understand what you have done?
can you explain it in detail? so maybe i can help you
br
joe
iDR32 & IPad1 & R72 & DANTE
*** less is more ***
Hi All,
thanx so much for all advises and input regarding my EQ problem.
It works like a charm now. I didn’t know the secret “right-mouse click” option to select source and choose post on all auxes.
Thanx
Hi all,
Maarten Louer
hi Maarten,
here’s another how to for you and all interested iLive users
Pan on StereoAux
br
joe
Hi Joe,
thanx for the very clear video’s you have posted. It helped me a lot.
Regards,
quote:
Originally posted by joefi
hi Maarten,
Pan on StereoAux
br
joe
Hi all,
Maarten Louer
