Hi.
Interested in the possibility of adding an equalizer before entering the reverb or delays and other FX. There was also the possibility of compression on the unit’s output.
If you re-route the FX unit to get input from a aux send and the returns to a “normal” input channel you get all you asked for.
Hmm, it would be easier when you can route the fx return directly to input channels with the whole processing as it is possible with other consoles.
@mfk0815 that is exactly what I was talking about. Route the fx return to a input channel! And for send processing (eq before the fx unit), use a aux send, instead of the fx send.
Hi.
in this case 2 additional channels (input and send) are definitely involved …
You have projects with that high of input channel count? And for the sends you loose nothing, as for the fx sends you cancel, you get additional mixes, which could be your aux sends for fx, no?
thanks it works !
welcome…
