EQ INDIPENDENTE SULLE MATRICI
Salve.
Come ho fatto notare qualche tempo fa, non mi spiego il perchè le matrici non hanno l’equalizzazione indipendente dal main e non posso assegnare su di loro singolarmente i canali di ingresso come se fossero degli aux.
In mancanza dei un terzo main (anche il behringer x32 lo ha), mi piacerebbe avere le matrici assegnabili, potendole usare appunto per creare più controlli di bus indipendenti, ad esempio controllare un front fill assegnando solo alcuni canali ed avere EQ indipendente che non influisca con il main principale.
grazie.
saluti, Diego
Hello.
As I pointed out some time ago, I don’t understand why the matrices lack independent equalization (separate from the main mix) and why I cannot assign input channels to them individually, as I would with aux sends.
In the absence of a third main bus (a feature even the Behringer X32 has), I would like the matrices to be assignable. This would allow me to use them to create additional independent bus controls—for instance, to manage a front-fill system by assigning only specific channels, while having independent EQ that doesn’t affect the main mix.
Thanks.
Regards, Diego
Translation:
Hello.
Thanks.
Regards, Diego
Response:
The matrixes already have GEQ and PEQ and Comp available at the output, independent of the main EQ. I would like to be able to assign individual channels directly to the matrixes. You can always use an aux buss to create a front-fill mix, if you have one available.
It seems that A&H has decided that the ability to assign a channel directly to a matrix is something to be reserved for their “higher end” console models like the Avantis and DLive. Clearly A&H has the ability to add this functionality to the SQ, but it is obviously a larger corporate “master plan” that has prevented them from doing so previously. Given how old the SQ is (and therefore how long A&H has had to change their mind), I doubt this feature will ever be added to the SQ (or lower) models.
Hi Brian,
agreed… the SQ is an older model but do you think A&H should consider this for the SQ+?
I think it would be an incentive to “trade up” to the new model if it really is capable of more power “under the hood” than the original and could accommodate this routing request…
Ti sbagli, Se provi a modificare EQ su matrice, sentirai che si modificherà anche su main e viceversa. Me ne sono accorto facendo delle prove e questa cosa la trovo assurda! Capisco il non voler sviluppare più SQ per dare priorità a Sq+ , ma almeno questa funzione potrebbero inserirla.
Saluti, Diego
Honestly I think that if A&H was planning on including this feature for the SQ+, I think they would have included it from the beginning. Of course that is just my opinion, but I think it has merit too. I guess only time will tell…
Salve Diego,
Non mi sbaglio: lo schema a blocchi mostra che il segnale inviato alla matrice proviene da un punto successivo alla sezione Mix Master. Il flusso non funziona al contrario: non c’è modo di modificare il segnale diretto alle uscite principali LR, ai gruppi o agli aux agendo sulle impostazioni delle uscite della matrice. Ho fatto diverse prove con il mio SQ6 e l’elaborazione dei singoli segnali in uscita non è cambiata quando ho modificato i parametri della matrice. A proposito, ho trovato una soluzione alternativa per inviare un singolo ingresso a una specifica uscita della matrice: assegno un ingresso locale a un’uscita diretta (Direct Out) e instrado quest’ultima verso un ingresso esterno della matrice. È assurdo dover usare un cavo microfonico per collegare un’uscita locale a un ingresso locale, invece di poter effettuare il routing internamente; a mio avviso, la doppia conversione AD/DA è un passaggio superfluo…
Hello Diego,
I’m not mistaken; the schematic diagram shows the feed to the matrix is post the Mix Master section. It doesn’t work the other way, there is no way to change the signal to the main LR, group or aux output when you make adjustments to the matrix outputs. I just tested this backward and forward with my SQ6 and the processing of the individual signal outputs did not change when I made adjustments to the matrix processing. BTW; I did find a work around for my need to supply a single matrix feed with a single input to a matrix output. I assign a local input to a direct out and route this output to a matrix ext. input. Stupid that I have to use a mic cable to link a local output to a local input instead of being able to map it internally. DA to AD is an unnecessary step IMHO…
Saluti, Diego
Translation:
You’re mistaken; if you try to adjust the EQ on the matrix, you’ll notice it changes on the main output as well, and vice versa. I discovered this while testing, and I find it absurd! I understand not wanting to develop SQ further in order to prioritize SQ+, but they could at least include this feature.
Regards, Diego
That is not how the schematic diagram shows how the system works. So either there is something being lost in the translation, there is a routing issue in your specific setup, or there is a bug in the firmware that is preventing the console from operating as designed.
Obviously if you have the Main L/R buss passing through a Matrix, and you change the EQ on the matrix, it is going to affect the overall tone of the audio being routed through the Matrix buss - including the Main L/R audio and any other busses being routed through the Matrix. I don’t know if this is what you mean, or if when you say the “Main Output” is affected when you adjust the EQ on a Matrix, you mean that the actual EQ processing on the Main L/R buss changes to match the actual EQ processing that you are changing on the Matrix Output.
The first example is expected behavior. The second example would NOT be expected behavior.
That could well be possible, given that the thread is starting to get confusing.
Couldn’t we just do without the interpreting, after all?
After all, being able to communicate in English shouldn’t be an issue for anyone these days.
And everyone else is trying to do the same - me too.
Here is that familiar routing diagram again which illustrates even more clearly that there is no (internal) path back from a Matrix to the Main LR mix.
Hi SQuser,
we are not interpreting, this is direct translation… What is the harm in translating for others to understand?
I understand English is not your mother tongue and I’m sure many others on the forum are the same. I translate this to English so other readers can benefit, as I’m sure many couldn’t be bothered to translate it themselves and miss out on the OP’s comments.
No harm no foul, just trying to make things more accessible for others…:wink:
That this created the following confusion:
Brian replied to and quoted timot - possibly without realizing that the text Timot sent to Diego was actually Diego’s own original text, including a translation and Diego’s signatures.
This shouldn’t be necessary, given that Diego demonstrated in his initial post that he is capable of writing in English himself.
But that was just my opinion.
If the others prefer it that way, then that’s fine too.
No offense! :upside_down_face:
I provided the translation to Diego’s original post, he has not posted on this thread in English.
No offense taken or given :upside_down_face:
Ciao Brian.
è proprio questo che intendevo!
Se il main passa attraverso le matrici, influisce con il suo EQ e non va bene, poichè non potrò mai essere indipendente con le matrici al 100%.
L’unico modo è usare solo le matrici come Bus e non usare il Main, ma non mi piace.
Spero che il mio desiderio possa essere accolto.
Grazie a tutti per la discussione.
P.S. Non so scrivere bene in inglese, scrivo in italiano e voi usate pure il traduttore!! :-))
Saluti, Diego
