EQ trim
A positive and negative trim (pre and) post EQ to compensate for large moves resulting in less or more energy.
You probably don’t need pre and post trim… if you’re trimming it down you want it pre-eq so that your large boosts don’t clip before you turn it back down, and if you’re trimming it up you want it post-eq so that you don’t clip before your large cuts turn it back down. Well, unless you’re emulating some specific analog circuit and you want to drive it a bit, but the board doesn’t do that right now.
Regardless, it’s a strong +1 from me… I want my eq to function as an eq, not an eq and an overall volume changer.
