Ext In tap point
Is it possible to select an Ext In: source select of an aux and tap into that channel pre processing?
I am wanting to duplicate a stereo Aux Mix to be processed differently from Mains and be fed to a broadcast mix. In some initial testing, if I send pink noise to Stereo Aux 1 and set the Ext in of Stereo Aux 2 to Stereo Aux 1, then PEQ changes on Aux 1 affect the sound of Aux 2 as well. Is there a way to select pre processing Source point when selecting a source? This would be similar to selecting source point from the routing page (see image.)
Images were too large in the OP. Here they are.
